Hi folks,
I want to submit the sitemap for my Articles to Google, where is this? I presume it exists?
Thanks,
Tom
View originalHi folks,
Thanks,
Tom
View originalHi @user877 , If you are looking for a Sitemap to download/upload to Google, afraid Intercom doesn't support that.
You can use online Sitemap builders for that, Like:
I hope this will be helpful 🦄
Ugh that's a pain. And it looks like no webhooks are sent whenever an article is updated/deleted/added, so we just have to run something every day to check.
Hey @user877, just to add to Roy's response, you don't need a sitemap for our Help Center. It's designed in such a way that Google can crawl it without one. You can read more about this here.
Is there are updated article about this? It’s going to a deadline.
