How to migrate selected articles from Zendesk to Intercom
View originalHow to migrate selected articles from Zendesk to Intercom
View originalHey
You can keep your your Zendesk Guide articles in sync with your Intercom Help Center and use them to power Intercom Support tools in the Messenger, Bots and Inbox for improved self-serve performance and team efficiency 🙌
Important to Note:
Synced articles and their content will be also retrievable from the Public API similar to Intercom articles. However, you won’t be able to edit or manipulate synced articles via API calls.
You can check out this article on how to get started.Â
I hope this helps!
Hi, I am planning to migrate only some articles from Zendesk to Intercom. Is there an option to do it? The only guide I can see is to migrate all articles from Zendesk to Intercom by using sub domain. However when I tried to use the subdomain, it just migrated some articles which are not the ones that I was supposed to transfer. So in case the only option is to migrate all articles, questions are
Thank you.
