I want to make sure some articles are only visible to users from specific countries. What properties can I use to make it happen?
View originalI want to make sure some articles are only visible to users from specific countries. What properties can I use to make it happen?
View originalHey
If you have audience targeting, you can select your articles to be visible to users from a specific country by adding an audience rule, as per the example below 👇
I hope this helps!
