So my need is to make sure every word, also the ones with hyperlink, are visible. Let me know ;)
Best answer by Eric Fitz
View originalSo my need is to make sure every word, also the ones with hyperlink, are visible. Let me know ;)
View originalCiao Monica 👋 the colour of hyperlinks in the body of an article will always match the Color you have specified in Help Center > Settings > Style your Help Center. If you have this set to white, your hyperlinks (and, indeed, the colour of the text of your Help Center collections and sections) will also show up in white!
