io.intercom.android.sdk.survey.block.AttachmentBlockKt.VideoAttachmentBlock
This strange error apeared to a single user 3 times on my app, i wonder what could it be
My app runs in Flutter, android version, The SDK version is
intercom_flutter: ^8.0.3
here the error stack:Fatal Exception: java.lang.NoSuchMethodError: No virtual method at(Ljava/lang/Object;I)Lt/q0$a; in class Lt/q0$b; or its super classes (declaration of 't.q0$b' appears in base.apk)
at androidx.compose.material3.ProgressIndicatorKt$CircularProgressIndicator$endAngle$1.invoke(ProgressIndicator.kt:16)
at androidx.compose.material3.ProgressIndicatorKt$CircularProgressIndicator$endAngle$1.invoke(ProgressIndicator.kt:2)
at androidx.compose.animation.core.AnimationSpecKt.keyframes(AnimationSpec.kt:7)
at androidx.compose.material3.ProgressIndicatorKt.CircularProgressIndicator-LxG7B9w(ProgressIndicator.kt:448)
at io.intercom.android.sdk.survey.block.AttachmentBlockKt.VideoAttachmentBlock(:513)
at io.intercom.android.sdk.survey.block.AttachmentBlockKt.AttachmentBlock(:284)
at io.intercom.android.sdk.survey.block.BlockViewKt.BlockView(:354)
at io.intercom.android.sdk.views.compose.MessageRowKt$MessageRow$6$2.invoke-RPmYEkk(:611)
at io.intercom.android.sdk.views.compose.MessageRowKt$MessageRow$6$2.invoke(:19)
at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambdaImpl.java:44)
at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambdaImpl.java:8)
at io.intercom.android.sdk.views.compose.MessageRowKt.MessageBubbleRow(:1133)
at io.intercom.android.sdk.views.compose.MessageRowKt.MessageRow(:793)
at io.intercom.android.sdk.m5.conversation.ui.components.MessageListKt$MessageList$12$1$1$renderMessageRow$1.invoke(:162)
at io.intercom.android.sdk.m5.conversation.ui.components.MessageListKt$MessageList$12$1$1$renderMessageRow$1.invoke(:8)
at io.intercom.android.sdk.m5.conversation.ui.components.MessageListKt$MessageList$12$1$1$2.invoke(:27)
at io.intercom.android.sdk.m5.conversation.ui.components.MessageListKt$MessageList$12$1$1$2.invoke(:10)
at androidx.compose.animation.AnimatedVisibilityKt.AnimatedEnterExitImpl(AnimatedVisibility.kt:813)
at androidx.compose.animation.AnimatedVisibilityKt$AnimatedEnterExitImpl$4.invoke(AnimatedVisibility.kt:27)
at androidx.compose.animation.AnimatedVisibilityKt$AnimatedEnterExitImpl$4.invoke(AnimatedVisibility.kt:8)
at androidx.compose.runtime.RecomposeScopeImpl.compose(RecomposeScopeImpl.java:30)
at androidx.compose.runtime.ComposerImpl.recomposeToGroupEnd(ComposerImpl.java:96)
at androidx.compose.runtime.ComposerImpl.skipToGroupEnd(ComposerImpl.java:30)
at androidx.compose.animation.AnimatedVisibilityKt.AnimatedVisibilityImpl(AnimatedVisibility.kt:139)
at androidx.compose.animation.AnimatedVisibilityKt.AnimatedVisibility(AnimatedVisibility.kt:345)
at io.intercom.android.sdk.m5.conversation.ui.components.MessageListKt.MessageList(:1603)
at io.intercom.android.sdk.m5.conversation.ui.components.MessageListKt$MessageList$14.invoke(:42)
at io.intercom.android.sdk.m5.conversation.ui.components.MessageListKt$MessageList$14.invoke(:8)
at androidx.compose.runtime.ComposerImpl.skipCurrentGroup(ComposerImpl.java:37)
at androidx.compose.runtime.ComposerImpl.doCompose(ComposerImpl.java:179)
at androidx.compose.runtime.ComposerImpl.recompose$runtime_release(ComposerImpl.java:32)
at androidx.compose.runtime.CompositionImpl.recompose(CompositionImpl.java:30)
at androidx.compose.runtime.Recomposer.performRecompose(Recomposer.java:71)
at androidx.compose.runtime.Recomposer.access$performRecompose(Recomposer.java)
at androidx.compose.runtime.Recomposer$runRecomposeAndApplyChanges$2$1.invoke(Recomposer.java:400)
at androidx.compose.runtime.Recomposer$runRecomposeAndApplyChanges$2$1.invoke(Recomposer.java:6)
at androidx.compose.ui.platform.AndroidUiFrameClock$withFrameNanos$2$callback$1.doFrame(AndroidUiFrameClock.java:10)
at androidx.compose.ui.platform.AndroidUiDispatcher.performFrameDispatch(AndroidUiDispatcher.java:33)
at androidx.compose.ui.platform.AndroidUiDispatcher.access$performFrameDispatch(AndroidUiDispatcher.java)
at androidx.compose.ui.platform.AndroidUiDispatcher$dispatchCallback$1.doFrame(AndroidUiDispatcher.java:16)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:970)
at android.view.Choreographer.doCallbacks(Choreographer.java:796)
at android.view.Choreographer.doFrame(Choreographer.java:727)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:957)
at android.os.Handler.handleCallback(Handler.java:938)
at android.os.Looper.loop(Looper.java:250)
at android.app.ActivityThread.main(ActivityThread.java:7886)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:592)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:958)
