How are article views in messenger recorded?
  • 14 March 2024
  • 13 views
Hi team!
Help Center articles that have been viewed through the messenger - will those views count when looking at reporting on article views?
icon
Best answer by Ebenezer.Laleye 20 March 2024, 18:55
Userlevel 2
Badge +3
Hi @Cecilia Bjerring Knudsen ! Ebenezer here from Engineering Support👋.
An article view is recorded anytime someone opens an article in the Messenger, or in your Help Center and will count towards the total number of article views.
You can use the Articles API to retrieve your articles, and check the statistics objects to see the total number of views an article has, the reactions that have been left, and the total number of conversations started from an article.
