SSL setup for Link Branding Question
  • 7 February 2024
  • 53 views
Hi
This may seem like a strange question but thought I’d ask
Can SSL be setup on a domain that is unhosted? The domain I want to use for link branding is just used for my email addresses via Google Workspace. So don’t need hosting for it other than for link branding.
Thank you.
Graham
icon
Best answer by aykut.aydin 15 February 2024, 04:18
Userlevel 3
Badge +3
Hey @Graham Cox,
Does Google Workspace allow you to create a CNAME record for your domain? If so, you can use the HTTPS (Quick Setup) option on your Help Center settings. To be able to use custom domain for your help center you’d need to create a CNAME record anyway, but the quick setup option also comes with built-in SSL certificate from Intercom. So you won’t need any additional configuration other than creating a CNAME record as shown here.
So to answer, your question, this depends on whether you are able to create a CNAME record for your domain on your Google Workspace panel or not. It would be a good call to check this with them if you are not sure.
Also note that the HTTPS (quick setup) will be disabled (greyed out) unless all criteria are met, which are as follows -
  • Make sure your Help Center website is turned on
  • Make sure you have at least one article published
Hope this helps! 😊
Hi Ayk,
Thanks for your reply. Unfortunately no, but I can set it up in namecheap. Is that still ok?
Assuming it is, let’s say I want my help center url to be help.hub-fs.co.uk, I’m not sure what to enter as the Target when setting up the CNAME record. On the article link it says:
“If you selected HTTPS (quick setup) in your settings note that the Intercom host domain will be different than the ones listed below. For quick setup they are:
  • Intercom US: us.intercomhelpcenter.com
  • Intercom Europe: eu.intercomhelpcenter.com
  • Intercom Australia: au.intercomhelpcenter.com”
but it doesn’t say what it will be?
Can you advise me please. Thank you.
Hi, can you advise me on this please, thank you.
Userlevel 4
Badge +5
Hey there @Graham Cox !
I couldn’t say for sure if NameCheap would support his or not. They would need to support setting up a Flexible SSL certificate so you may need to check that with them. That said, that is only required if you are trying to set up your Help Center with manual SSL setup. If you do the Quick Setup, then you don’t need to set up SSL with anyone. We would do that for you.
You would need to use one of the Host URLs shown below if you are setting up Quick Setup. This is mentioned in our docs here
